Nav and Bluetooth Update for 2006 LR3 HSE
Old Feb 6, 2020 | 03:29 PM
flyer08's Avatar
Default Nav and Bluetooth Update for 2006 LR3 HSE
I see some discussion about a 2016 nav update. Is this real and good? Is there a newer version as we now hit 2020? Some say the update does not work while moving. One person wrote it gave a better 4x4 screen.
Is an update available and what changes to the system, if any, to the screen?
The 4x4 info showing locking plus other info a must. Also, I have to pair the phone to Bluetooth ever time I get in the LR3. No music from phone, no contacts from phone. Just voice.
Old Feb 6, 2020 | 05:12 PM
Fmwrightjr's Avatar
Where is the update coming from?
Old Feb 6, 2020 | 05:48 PM
DakotaTravler's Avatar
Im not aware of any update like this. More details please. Although I have a totally different Nav system from a LR4, I am still very curious.
Old Feb 6, 2020 | 09:24 PM
There are discs out for the LR3 system that update the maps to 2016 any updates beyond that I haven’t heard of
Old Feb 6, 2020 | 10:56 PM
flyer08's Avatar
Actually just below in 'Related Topics' LR3 Stock Nav
https://landroverforums.com/forum/
Has info:
Originally Posted by DavC
Wrong. Nav-on-move works with the 2016 map data. That old input the code method does not work yes, but the GAP reflash for Nav-on-move will work with the new disc.
I have used it several times already
and
Originally Posted by dijkvr
Last version made for LR yes, but other car brands like Subaru, GM, etc. use same Core 1 navigation. This road data combined with LR Firmware works !
In Europe same situation LR , RR,RRS Disco3 2004-2009 work on a 2014-2015 version W European map.
from different thread
Originally Posted by bbyer
Yesterday I received dijkvr's Nav disc via Canada Post. I got it in less than two weeks so that is pretty good. I ordered the disc on May 21 and it was here May 31, only 11 days.
Even better news, is that the Polar Bears and Dragons in the uncharted regions of the previous disc for the most part have been replaced by roads plus evidences of an advanced civilization such as Starbucks and McDonalds.
A local ring road that is just being completed around our village is very much there, plus to my surprise, a real obscure almost trail called Cemetery Road that runs the backside of a local cemetery is also there - that did surprise me.
Also "Nav on the Move" still works with the new disc. This does not surprise me as I had previously enabled "Nav on the Move" via a software upgrade with my BlackBox Evolution. If you have a Gap IID, you can also do the upgrade.
If instead, you had previously the original circa 2005 DVD and used the 1791 hack, well you will lose that and short of the LR/BlackBox/Gap software upgrade, there is not much you can do about that.
To summarize the disc install procedure , either start the engine or at least turn the vehicle ignition on so the Radio/DVD/Nav powers up.
Then raise the drivers seat to full height and also run it full forward.
Have a flashlight handy and you will now see the DVD player under the seat on the carpet.
On the "outside door of the under seat area side", find the lock-unlock slide switch and with your fingers, unlock.
On the tranny tunnel side, there is an eject button so then push that and the current CD will eject. Again, fingers only as there is only that much room, remove the old DVD and push in the new one, shiny side down. Slide the lock slider back to lock and then reset the seat.
As you might gather, I am pleased with the new disc.
a must read link>>>> DISCO3.CO.UK - View topic - Alternative Engine Temp Reading
This covers a lot, it is from 2016.... hoping for some updated info and best solution.
Seems there is a 2016 version. Have PM out to confirm and cost. Still looking for best and Bluetooth update
Old Feb 6, 2020 | 11:04 PM
flyer08's Avatar
Hey Dakota Travler,
Looks like there is an update for all LR3 without a hack. Working to confirm
Old Feb 8, 2020 | 07:24 PM
If you want the best bluetooth update, just slap in an LR4 bluetooth module and call it a day. It will be far batter than any updated LR3 module.
Old Feb 9, 2020 | 09:39 AM
flyer08's Avatar
How do you slap in an LR4 Bluetooth module.
I saw your post putting the LR4 screen in the LR3 and Wow! That was impressive. But what a job to tackle! Are you talking about your entire mod in that write up, or is there a less intimidating LR4 Bluetooth only plugin?
Your full screen and unit mod from LR4 to LR3 was great. The touch screen of more 4x4 functions you found after mod is not in the LR3 screen. Those extra touch screen functions came from the LR4 module and your excellent work.
Old Feb 9, 2020 | 09:38 PM
I will have a write up about the LR4 Bluetooth module swap. The module is in the back of the truck, easy to get to. I want to have the proper connector before I do it. They LR3 and LR4 connectors are different, but only TWO wires are used, just for power. So its super easy to swap. But my connector was tied up in China for a while because of that outbreak situation. Looks like today it made it to Chicago finally. So hopefully this week I will have it done.
Columbiar
Aug 28, 2017 01:16 PM
k2sb2003
Apr 30, 2015 10:04 PM
comleader
Mar 3, 2013 07:12 AM
pep100
Nov 14, 2008 11:24 AM
jlee301
Oct 12, 2008 04:47 PM
