New Front Discs and Pads - Pedal now goes to floor
Old Aug 15, 2013 | 11:35 PM
churious's Avatar
Exclamation New Front Discs and Pads - Pedal now goes to floor
Gentlemen...
As the title states tonight I replaced the front rotors and pads on my rig. OEM discs and Textar pads. Everything went perfect. Gen in the rig to test drive and pedal is a bit soft as usual. I pump it a few times and the stiffness comes back. Go on a drive to break in the pads and everything seems great. Car stops great but the pedal is a bit softer. Then I stop a couple times put her in park and pump the pedal. It pumps up but then at the end gets soft and goes to the floor. WTH?
I did not break the system and slowly pushed the calipers back with a pad and c-clamp and slowly foot pumped the system the first time.
Does the system need bleed? Master cylinder going bad?
Old Aug 16, 2013 | 12:26 AM
bleed - here are some pages torn from the shop manual
File Type: pdf
File Type: pdf
Old Aug 16, 2013 | 07:57 AM
drowssap's Avatar
did your pedal go to the floor before you replaced the pads and rotor?
Also the days of collapsing caliper pistons with C-clamps went out with the introduction of ABS.
When you compress the caliper you are FORCING all the fluid back threw you ABS controller, not good.
If you are not going to rebuild the calipers you should open the bleeder while collapsing the piston to avoid damage to the ABS controller
Old Aug 16, 2013 | 11:13 AM
churious's Avatar
Actually I believe I just didn't drive the rig enough. The pedal has now firmed up and everything is perfect.
Andytats
Mar 27, 2022 01:40 AM
Externet
Sep 13, 2013 12:27 PM
Tony Crosland
Feb 27, 2013 03:45 PM
Miss Rover
Jan 29, 2013 11:24 AM
marlymarl
Apr 21, 2012 12:49 PM
