New LR3 Owner (Quick Question)
Old Apr 15, 2018 | 08:35 PM
Chance888's Avatar
8th Gear
Originally Posted by spannermonkey
If you don't have it already, get the Gap tool, its worth every penny
This is DEFINITELY something that I plan to purchase. It looks like there are different brands or types. Is Gap IID a specific make and model or just a general name? Which one do I need and where would be the best place to purchase it?
Old Apr 15, 2018 | 09:47 PM
spannermonkey's Avatar
Products Archive - Gap Diagnostic
Old Apr 15, 2018 | 09:53 PM
houm_wa's Avatar
Gap Diagnostics is the brand. IIDTool is the product.
Great advice above. I am not sure about the metal transmission pan as I've not yet been convinced that it holds the same amount of fluid as the original.
Old Apr 17, 2018 | 10:24 AM
EastCoast's Avatar
I would add that if you don't want to do the cowl at this time, seal it with some black Gorilla tape. I did mine when I bought it 2 years ago as a temporary fix as there were more pressing matters to attend to. Two years later and the tape still looks great (can't tell it there unless looking closely) so I've left it for now. Worse thing to do is leave a "slight" gap in your cowl unattended.
Old Apr 18, 2018 | 09:44 AM
Chance888's Avatar
8th Gear
Better safe than sorry, right? I put some strips of 3M Black Cast Vinyl over the warped areas. I’ll buy a new one and change it out eventually. In order to replace it, do you have to take the hood off?
Old Apr 18, 2018 | 10:27 AM
KMET's Avatar
No, just the wipers.
Old Apr 18, 2018 | 05:12 PM
DakotaTravler's Avatar
If you do the cowl, I HIGHLY recommend you get the a-pillar repair kit and make sure those leaks are corrected also. Cheap enough on eBay for new clips/kit. I say this because removing the a-pillars makes replacing the cowl a lot easier. Then you know leakage wise you are good - less the sunroof drains...
But I will second that some tape will help seal it up for now. Even a small gap can be bad. I used cold-weather electrical tape until I did mine. New cowl, $80.00.
File Type: pdf
jsbowen
Discovery Sport
May 10, 2016 02:03 PM
01d2Jeff
Oct 18, 2011 01:45 PM
icyhot201
Aug 16, 2010 07:24 PM
endneu913
Nov 3, 2007 03:46 PM
UNCRover
Apr 30, 2005 03:42 AM
