New Rims and pressure sensors
Old Jun 7, 2014 | 04:49 PM
RAJOD's Avatar
Thanks for the lead!
Old Jun 7, 2014 | 10:47 PM
driver_42's Avatar
The hard aluminum style stems are not used as much any longer. They have a problem with the valve caps not coming off or corroding and breaking the stem off. Now the common style is a snap in rubber stem that has the sensor screwed to the inside end of the stem. Normally they come with two radio waves either 315mhz or 433mhz. Both are made in after market brands that cost about $70.00 each. Most tire shops should be able to fit and learn the sensors for your truck.
Old Jun 8, 2014 | 03:16 PM
RAJOD's Avatar
Say for instance I wanted to sell my current rim. I wanted to keep the rubber and sell just the rims.
I take the rubber off and what do I have?
I have 4 rims and each rim should have that radio sensor in it right?
Its part of the rim and not the tire correct?
Old Jun 8, 2014 | 03:41 PM
jafir's Avatar
It's not part of the rim and it's not part of the tire. It's its own separate part.
Old Jun 9, 2014 | 07:07 PM
RAJOD's Avatar
What I meant was it would still be attached to the rim. It would not just fall out. Something has to hold it to the rim, clips etc.
So if I took the tires off the rim the part would stay on the rim unless I did additional work to remove this part from the rim.
Meaning people have to manually remove them from a rim, they don't fall off on their own?
Old Jun 9, 2014 | 07:08 PM
jafir's Avatar
Correct. They attach to the wheel with a nut that tightens around the valve stem. At least the ones I have attach that way.
rreinholt
Sep 19, 2013 07:46 AM
crtfour
Dec 20, 2012 08:39 AM
05lr3guy
Sep 17, 2010 09:25 AM
RoverDude71
Mar 2, 2009 11:03 AM
morfa
Aug 27, 2006 01:22 PM
