New Tires
Old Dec 22, 2008 | 04:26 PM
  #41
alexbc99's Avatar
5th Gear
Default RE: New Tires
Hi All - new to the forum. Some great info here on tires. I have an 2005 LR3 SE with the "ever-exciting" HPs and like most others here, I am looking to see what tires I should go with when I change and upgrade. The Silent Armours seem to be the way to go for, so far anyway. I do limited off-road, but love to have the capabilities, just in case! I noticed on Tire Rack a couple others didn't know if anyone had any info or comments on these: Bridgestone Dueler A/T D695 or Michelin LTX A/T 2's. Both were at the top of the ratings per Tire Rack for their category at the 265/60/18 size. Any comments are appreciated! Thanks
Old Feb 8, 2014 | 04:33 PM
  #42
RAJOD's Avatar
Well its been some time but have not really seen a ton of good reviews on those Goodyear Silent Armour Tires. Below are just a small sample of the quotes of previous owners.
TERRIBLE off road integrity - popped 4 of them without trying. This tire is quiet, has excellent traction in snow, has a long lifetime on highway but is so flimsy I pop one almost every time I go off road. I'm by no means an aggressive off road driver and I've never had such a problem with any other tire I've used in over 40 years of driving off the highway. DO NOT BUY this tire if you're looking for something to use in the dirt or on rocky trails!
Put these tire on my F250. Worst handling tires I ever had in winter. There is nothing good about them. The Firestone Transforce LT235/85R16 is an absolute dream.
Started hearing a noise in back, dealer said the tires are cupped and out-of-round in 6000 miles. No defects with the vehicle detected to cause this. He advised these tires are not typical of Goodyear and has seen it before. I'm stuck for the next several years with these and am pissed off."
Old Feb 8, 2014 | 07:43 PM
  #43
unseenone's Avatar
Nitto Terra Grappler would be a great tire for you.
Old Feb 8, 2014 | 11:44 PM
  #44
RAJOD's Avatar
I'm running Perelli Scorpion Zeros right now. Very nice in the rain, no hydroplaning. And not bad in the snow either. Not been stuck yet and the zeros have a nice highway ride they don't sway much while turning or lane changing.
Old Feb 12, 2014 | 04:39 PM
  #45
oljohnboy's Avatar
I have nitto terra grappler stock size. they wear amazing. This is my second set I got 50,000 off my last set and the traction is amazing. It has been snowing here in NC, while everyone is doing 25 I can go 35-45 easy. I know that the traction control is a big help but my footprint shows deep solid traction. I am sold on these tires
Old Feb 12, 2014 | 09:04 PM
  #46
mx468's Avatar
Default Hankooks AT's 265/60/18
I got the hankooks at's and they are amazing. I've had them for about 2000 miles and they ride very smooth on the highway and are great in the snow. I went with a smaller size because they run much better in the snow. I had the nitto grappler's before 285/60/18 but found them to be a bit too wide for my taste on the LR3's stance and loud on the highway compared to the hankooks. Don't get me wrong, they are pretty good tires but I find the hankooks to be slightly better, so far. Also with this smaller tire size you can put snow chains on if you want that extra grip.
Attached Thumbnails  New Tires-img_5020.jpg    New Tires-img_5022.jpg    New Tires-img_4199.jpg
Old Feb 13, 2014 | 08:37 AM
  #47
jerdog53's Avatar
I personally have been considering some 255/70-18s which is a 32.1 x 10.04 x 18 in a Toyo Tires Open Country A/T2 orCooper Disco A/T3.
I am thoroughly disgusted with the fact that the major mud tire manufacturers like BFG or Goodyear for example don't make smaller mud tires for 18" wheels like a 265...
Old Feb 14, 2014 | 12:12 AM
  #48
Delray's Avatar
I just put on the Toyo Open Country A/T II 255/70 R18
New rims also. I will post some pics. With stock rims there is a little rubbing in the rear, toward the front of the wheel-well when turning in reverse (my co-worker has this setup)
My aftermarket wheels push the tires out about 3/4 so I am getting no rubbing in the rear, but some in the front when going in reverse and wheel turned about 50%. I had to trim away some of the plastic lip that extends past the bumper with a utility knife. This is normal suspension height and off-road. Not much different at access height. More to come.
Old Feb 14, 2014 | 08:18 AM
  #49
jerdog53's Avatar
I would like to see this set up!
Old Feb 14, 2014 | 12:01 PM
  #50
Delray's Avatar
Hey jerdog53, here is the setup. Not great pictures, but you can compare...
http://www.4wheelparts.com/Tires/P25...t_pn=TOY352250
http://www.4wheelparts.com/Wheels/91...BRW910B8852060
Installed
SAME RUBBER, stock wheels on my friends LR3, and mine at super-off road height with Johnson Rods
SAME RUBBER on stock rims (Friends LR3)
IMG_3013-2_zps47166763.jpg Photo by qanae | Photobucket
