New Upstream O2 sensor totally stuck
Old Feb 20, 2026 | 08:07 AM
Tristan Stumpf's Avatar
Default New Upstream O2 sensor totally stuck
Hey gang,
I put in some new Upstream o2 sensors to solve a problem. I decided to be dumb and bought cheap aftermarket ones thinking that I would just return them if they were faulty.
I got the old ones out with little trouble, finger tightened the new ones in finished them with a ratchet.
Long story short, one has failed. The one behind the drive shaft. I tried to remove it but I couldn't. I took it to a mechanic and they tried everything including managing to fit an impact to it. It would not budge a bit. I have absolutely no idea what happened. It's somehow welded itself into place?
At this point I am thinking I can drill a small hole somewhere and put in a clamp on O2 sensor bung. I don't think there is any clearance to weld something in.
Does anyone have a better idea?.
Old Feb 23, 2026 | 11:49 AM
David Eubanks's Avatar
4th Gear
Try this. https://www.autozone.com/p/crc-multi...store_set=true
DiscoNickBK
Sep 5, 2019 04:13 AM
Luckyjayb
May 23, 2017 10:49 PM
LandyMatt
Nov 29, 2015 07:50 PM
EATMAN
Nov 10, 2006 12:15 AM
