No left signal/brake on trailer
Old Sep 17, 2008 | 08:37 PM
rmoraski's Avatar
Default No left signal/brake on trailer
I have an '05 HSE to which I added a towing wiring harness. From the start, the right turn signal and brake light worked on the trailer (4-pin harness); the running lights and left signal/brake light were dead. I dug around and found that fuse 14 behind the glovebox was blown. Replacing that revived the running lights. More digging and owner's manualing led me to spend several fruitless minutes looking for the "supplemental fuse block" for towing electronics in the left rear panel where the tow hitch normally resides. I found no such block, then went to Google and found one reference here to the towing fuses actually being behind the glove box. I see only the main fuse panel there, which had only the single blown fuse (which wasn't labeled running lights). I don't see the six fuses mentioned in the manual.
Any ideas?
Rich
Gerard
Mar 1, 2013 01:20 AM
Thatdudeuno1
Mar 11, 2012 11:13 AM
dparham
Dec 10, 2011 10:09 AM
Gomie
Feb 3, 2009 03:16 PM
LordOphidian
May 30, 2006 03:00 PM
