OBD Trouble Code Index
Old Aug 14, 2014 | 04:48 PM
ljdiscovery's Avatar
Default OBD Trouble Code Index
Hi, Does anyone know what these codes are or know where a complete index of codes can be found?
Range Rover Sport 2006
P0500
P0198
P0071
P0851
thanks
Old Aug 14, 2014 | 08:03 PM
roverguy7's Avatar
I check the LR3 section more often the the RR section, so I'll copy and paste my response here as well...
P0500 - Vehicle speed signal invalid - This is based off of ABS signal over HS CAN
P0198 - Engine oil temp sensor signal high - Never seen this fault on this engine, but fault could be open circuit, so I would check wiring first, sensor is mounted next to pressure sensor in the oil cooler(where the filter mounts)
P0071 - Ambient air temp sensor signal high - Seen this a few times, but not too common, seen both wiring and sensor issues. Sensor is located mounted to the back of the bumper support rail, behind the grill.
P0851 - P/N input invalid - Each time I've seen this it has been erroneous, and will clear and stay away(P0850 is a different story)
To digress, are you having any ABS issues/warnings? What does the temp display in the dash say? Any overheating issues?
Old Aug 14, 2014 | 09:59 PM
Codes were U0155, U0101, U0121, P0500, P0198, P0071 and P0851. The truck was in an minor front end accident at 15k miles and has been sitting for 6 years. Water got into the battery box and on the surrounding modules. The truck was running when some body work started, the radiator and oil cooler have been removed and the right front quarter panel was replaced. That is when it was put into storage.....phil
Old Aug 15, 2014 | 12:39 PM
roverguy7's Avatar
U codes, or comms codes are not abnormal to have, as long as they don't come right back you will be fine.
These are also not always 'communication lost', they can be 'invalid data' so say there is a failed wheel speed sensor(possible cause of the P0500) this would fault the ABS, and the ABS would then send out an 'invalid data' message, which would flag a U code.
Old Aug 18, 2014 | 09:26 PM
yes, there is an ABS fault listed as well uo 121 lost communication with atni-lock brake system ABS control module. The truck isn't running right now so I don't know if it has overheating issues. I doubt it. It only has 15k miles on it. It was in a light front end accident a few years back. I got it and am trying to get it up and running.
it is showing a transmission fault, limited gear, E on the dash
Bonnet open
suspension fault
parking brake fault
neutral switch fault Phil
Old Dec 2, 2018 | 12:22 PM
Rick510's Avatar
Default Can you post pics
  • Can you post a picture of where to find the sense are you talking about for code P0071 I got a headache just trying to find this issue if you can help it be gladly appreciated
WarrenZ
Mar 6, 2017 09:12 AM
ljdiscovery
Aug 14, 2014 08:01 PM
CaptainCulp
Oct 24, 2013 01:34 PM
myquealer
Feb 11, 2012 03:56 PM
loic
Feb 10, 2008 09:48 AM
