Oh no! Amber check engine light
The throttle plate gets oil carbon build up which can result in this condition.
Let us know how you make out.
Tratcliffe (02-29-2016)
Too lean is an air leak or under reporting MAF sensor. I would try cleaning the MAF with proper cleaner and also remove the throttle body and clean it really well.
I will try those things, but I must say I know very little about the MAF and throttle body. Any suggestions on cleaner for both. Maybe I can find a video that shows how to remove and clean. Thanks a bunch for the previous info and any subsequent info on cleaners. Also any idea what a new MAF sensor might run or where to by one other than dealer?
You can use any throttle body / carb cleaner you see at advance or similar stores.
Atlantic British always gets my business for LR specific parts. This link will show the sensors for the LR3.
Alrawas (01-12-2017)
