Ok I need the brain trust, I have one angry LR3
@ArmyRover Following your journey on this one. Why would an engine ECU be a death sentence? I saw another recent thread that mentioned a new could be bought and programmed. TIF.
Ok I had a lot of suspension errors coming up and a red suspension fault light found a wire had come loose on the coil conversion module so fixed that and I’m down to the following
p0102-00(AA)
p2105-00(2A)
p0480-14(2A)
U0100-87(FB)
U0401-68(2B)
I have swapped out throttled bodies, MAF, checked for vacuum leaks getting 14+ volts when running. Having the battery load tested today as well voltage is good but worth a check. I have checked all the harnesses for corrosion all were clean and clear. Going to do some pin out tonight check voltages and continuity
information center is giving
suspension lowered
transmission fault limited gears
hdc system fault
engine system fault
only other idea I have if the checks above result in nothing is a used pcm, cluster and ignition. Anyone else have any ideas or things to check
p0102-00(AA)
p2105-00(2A)
p0480-14(2A)
U0100-87(FB)
U0401-68(2B)
suspension lowered
hdc system fault
engine system fault
mdisalvo
Jun 28, 2023 07:29 PM
