A/C Issues - Please Help
Old Apr 17, 2024 | 06:08 PM
RChives85's Avatar
4th Gear
Default A/C Issues - Please Help
Newbie here - I'm having issues with the A/C on my 2010 LR4. Last summer the car needed a recharge - we did that and all was good for a few months, then it stopped working.
Fast forward to this summer, I have absolutely no A/C - it only blows hot air. We have replaced the AC compressor, flush the system, checked for leaks and refilled. No leaks.
I'm getting the following codes when I run the GAP tool:
B1A59-13: Sensor 5 volt supply circuit - General electrical failure - circuit open
U0422-86: Invalid data received from the body control module - bus signal/message failure - signal is invalid
U3000-55: Control module - System programming failure - is not configured
B1311-87: Clock module - Bus signal/message failure - missing a message
U0164-00: Lost communication with heating ventilation and air conditioning control module
Rear heating ventilation mode actuator position: Face
Left air blend actuator position: Invalid
Thank you!!
Old Apr 17, 2024 | 10:49 PM
guy's Avatar
guy
Hmmm, given those codes, is the replacement compressor oem? Used and not mated to the vehicle?
Actually, I defer to @jahummer …. Didn’t you go through this??
jbullock78
Oct 16, 2024 10:34 PM
TravelingLR3
Mar 5, 2024 09:08 PM
Dixie
Nov 5, 2023 09:39 AM
bluetick
Jan 6, 2019 08:31 PM
