outer tie rod end
Old Feb 17, 2016 | 07:40 AM
Lr3mcclung's Avatar
Default outer tie rod end
is it worth it to replace the outer tie rod and lower ball joint myself or should I get a shop to do it. if I do it myself what are the major issues that seem to pop when someone does this repair?
Old Feb 17, 2016 | 05:52 PM
Boulderhead's Avatar
Haven't done these jobs on the LR yet, but most common issue with suspension parts is getting bolts / nuts to crack loose without breaking them, and since you are working on the front end you will need to get a professional alignment once done or be prepared to burn through a set of front tires in short order.
Do you typically work on your own vehicles? If so, this job shouldn't scare you off.
Old Feb 18, 2016 | 12:24 PM
Lr3mcclung's Avatar
yes I have, I was just wondering how much of a pain this would be and if it's worth doing myself. I looked at it last night doesn't look to bad. I started with wd-40 and will do this for a week before I start to help loosen up the bolts.
Old Feb 18, 2016 | 12:37 PM
Nice, good thinking!
Old Feb 18, 2016 | 06:02 PM
Niver39's Avatar
It's very simple I replaced my outer and innerspring about two months ago. Just make sure you can get aligned right after you complete the tie rod job.
Old Feb 19, 2016 | 08:29 AM
abran's Avatar
Sea foam deep creep.
It's insane. I turned a local LR tech onto it and he was amazed. It's really that much better than wd.
Old Feb 22, 2016 | 07:27 PM
mx468's Avatar
Is this stuff better than pb blaster, or on par?
dfauver1
Apr 9, 2014 05:49 PM
TRIARII
Feb 21, 2013 10:33 PM
Cottrell
Sep 20, 2012 01:24 PM
Clunker
May 9, 2011 08:16 PM
Christian_X
Oct 27, 2008 05:54 PM
