Overheating with no heat plus "water" leak under truck
Old Jul 19, 2016 | 10:04 AM
lr3_ovrlnd3r's Avatar
Originally Posted by BritishautoworksSD
If you guys have an air compressor, get a vacuum coolant filler. Pulling a vacuum on the coolant system. This vacuum is then used to fill the system thru suction. Works very well. I don't even try to fill the old fashion way anymore.
UVIEW 550500 AirLift II Economy Cooling System Refiller
$85 on Amazon- but only works with an air compressor
Guess what just got ordered from Amazon...LOL....I have a D2 I am about to get busy on. My indy over torqued the head bolts stripped the block. So now it's time to order ARP studs, thread insert kit (not helicoils) and gasket kit. figure while in there, rocker arms, rockers, tappets, pushrods and springs are getting replaced. Oh but I digress, especially in the wrong forum. Thanks for the heads up on the Refiller. I can see this will be a busy tool soon.
Old Jul 19, 2016 | 01:38 PM
abran's Avatar
Also when its under vacuum you can tell if they are leaks before refilling the coolant.
Old Jul 20, 2016 | 12:09 AM
Zelatore's Avatar
FWIW, I've used Time-serts to repair stripped head bolts on 454s with success. I prefer them to helicoils. Sorry for the out-of-topic post but thought it worth mentioning.
Old Jul 20, 2016 | 10:11 AM
Exactly, I will be swapping over to head studs as well. Will be using either TimeSerts or NS300L kit, both are steel or stainless inserts rather than a short little "Spring". Gotta get the weekend warrior ready for battle.
jycsalas
May 23, 2019 03:02 PM
jmason
Nov 17, 2013 06:39 AM
Snafu / Disco Fries
Apr 13, 2011 05:40 PM
mag48
May 18, 2009 09:52 PM
