P0171 code
Old Aug 25, 2023 | 03:12 PM
LRohio's Avatar
Default P0171 code
Recently acquired (two weeks ago) an 05 LR3 with 74k miles on it. I was doing some routine maintenance and after changing the air filter (which was full of leaf particles) I got this code. Lean code 0171. Car runs and idles fine. I rechecked the seating of the filter and see no cracks in the filter box or tubing. I cleared the code and it’s back on 30 miles later. I have tried some seafoam as well. I just replaced the MAF sensor and cleared the code and it came back on within 20 miles.
I do have a PCV valve and some fuel injector cleaner that I will try next. Anything else moderately easy to try before I take it to the Indy shop? (Fuel pumps/injectors are beyond my skill/time available). Thanks
Old Aug 26, 2023 | 10:03 AM
tracyc's Avatar
Lean codes on these are typically from unmetered air leaks - not always but usually (there are soooo many lean code threads in the forum archive). You probably disturbed the air inlet tubes enough to allow a crack or dry seal to let air through downstream of the mass air flow sensor.
Just fyi, if you're going to throw a MAF part at it, only use a Denso or oem Land Rover one - anything else is known to be trouble with these.
Old Aug 26, 2023 | 04:24 PM
LRohio's Avatar
Well, I replaced the PCV valve and drove about a 100 miles today and it appears to be fixed. I did pay particular attention to the resonator clamping. It now has noticeably more power at low RPMs and idles a bit quieter.
The MAF sensor I have is a Delphi from Atlantic British. I kept the old one and will clean it since it likely wasn’t the problem. I also still have seafoam working through the tank, which may have helped.
Old Aug 26, 2023 | 06:03 PM
tracyc's Avatar
Clogged injectors can also cause lean codes - fingers crossed that was it and they're cleared up now. You might want to also do a can of BG44k in the tank before your next oil change. It's strong stuff, so the recommendation is to change your oil after running that through - I suppose because it can loosen up and deposit some carbon in your oil....
Old Aug 26, 2023 | 08:50 PM
tracyc's Avatar
By the way, there are a number of reports that the Delphi MAF often doesn't work right in these (just saw another such report on a Facebook LR group today) - so if it turns out you do actually need a MAF, Denso is still the only bulletproof choice.
Old Aug 27, 2023 | 02:13 AM
LRohio's Avatar
The one I took out and still have is the OEM Denso, which I will clean and keep just in case. But since the light is off now and it’s running a bit better, I’m going to leave well enough alone for now.
Old Aug 29, 2023 | 02:31 PM
LRohio's Avatar
Now this is funny. I put in a bottle of BG 44k and about 2/3 of a tank of gas into it, light came on it’s now reading P0172 and P0175, too rich in bank 1 and bank 2. Probably going to fill it up and reset and let the computer adapt over time.
Old Aug 29, 2023 | 05:09 PM
tracyc's Avatar
They are a source of constant amusement if you have the right state of mind
I'd just let it run through the 2/3rd tank personally and see where you are when that is used up.
Old Aug 29, 2023 | 05:37 PM
LRohio's Avatar
I did buy this as a project car. I might have an excuse to clean the throttle body now.
Old Aug 31, 2023 | 06:16 PM
LRohio's Avatar
So, for posterity, the check engine light went off and the codes cleared after about a half tank after the next fill up. Changed the oil and it was very black. That BG 44k must be strong. I am definitely getting a smoother idle and more low end power. I also am getting about 2mpg better in mixed driving.
Audrey Mateer
Nov 6, 2017 12:28 PM
vithooantony
Defender
Nov 25, 2014 11:23 PM
jrch20
LR2
Mar 25, 2013 05:54 PM
blcp86
Apr 15, 2010 10:43 PM
masonstewart
Oct 19, 2006 07:26 PM
