P0171 and P0174 Codes // Lean Bank 1 and 2 (long post)
Old Jan 4, 2023 | 08:29 PM
  #91
droolyFace's Avatar
THANK YOU! That is going to be a huge help.
Old Jan 4, 2023 | 08:33 PM
  #92
droolyFace's Avatar
One more question: the manual references the special tool to disconnect the fuel line at the back. What'd you guys use if you've done this?
Old Jan 4, 2023 | 09:48 PM
  #93
P-Bod's Avatar
https://www.rockauto.com/en/parts/pe...nnect+tool,328
I have not used it, but this crosses to the tool number in the book.
Old Jan 5, 2023 | 05:38 PM
  #94
droolyFace's Avatar
It’s done but not starting.
It turns on, revers really high then stalls and dies.
Im guessing no fuel in the fuel rail but have no idea how to get it to prime and fire.
Ideas ?
Old Jan 6, 2023 | 09:27 AM
  #95
P-Bod's Avatar
Dang it! I don't think there's any magic at this point. Double checking your work and checking for codes for any clues on where to look.
Old Jan 7, 2023 | 10:57 AM
  #96
droolyFace's Avatar
Alright, I got it working last night. As mentioned somewhere, I replaced the new upper manifold gaskets with the old ones I took out. The truck was hard reset and then I also reset the adaptation values.
Important note on the upper gaskets - they are VIN specific in that there is a cutoff as DakotaTraveler noted.
So I went for a nice drive this morning and it ran great. As I was joking with my wife last night, I told her the engine light would come back... and it did after an ignition cycle. So the light and same lean codes are back and I get to order the right gaskets and do this a 3rd time. I''ll do another smoke test and see what I see although that should be after all the new gaskets are in.
Here's a PDF log from this morning's drive. Where the levels top out in the 20's for long and short term it's when I was stopped at a light, or in park idling and watching.
This is very interesting and has motivated me further to track this down.
File Type: pdf
Old Jan 8, 2023 | 07:04 AM
  #97
jbullock78's Avatar
The farthest I got with new fuel injector O-rings/seals was 75+ miles before the codes popped back. Usually after turning it off (to get gas etc). I am going to try the Evap tube trick. We shall see. I appreciate all the comments/suggestions here. I feel like Ahab chasing the elusive white whale!
Old Jan 8, 2023 | 07:58 AM
  #98
jbullock78's Avatar
What did you do with the Evap/purge tube? did you just leave it disconnected or remove it completely?
Thanks,
James!
Old Jan 8, 2023 | 12:17 PM
  #99
P-Bod's Avatar
I left it hanging but stuck a backwards vacuum cap in it to keep it clean.
It’s been this way now for 7 days and 271 miles of daily driving, mostly short 10-20 mile drives and several highway drives 80+ miles per hour 20-30 miles or so.
No lean codes. I still only have the P0441 evap code.
The only caution I might have from doing what I’m doing is there may be a risk of saturating the charcoal canister. I believe the purge system is responsible for keeping the charcoal clean.
I still don’t know why this seems to be keeping the lean codes away, but it is.
Old Jan 8, 2023 | 12:43 PM
  #100
DakotaTravler's Avatar
Another thread I dont want to read over again, plus so many people adding their issues. But.... gas cap anyone? The fuel filler cap has a critical roll in the evap system and can indeed fail causing a vacuum leak. I *think* the LR3 is suppose to be smart enough to infer a gas cap issue and throw a code for it, but I am not certain. Editing to add: I think evap only runs a purge cycle on startup and that it is generally closed. But if stuck open - gas cap failure can cause lean.
As for running with evaporation system disconnected, I really do not see any issue in doing so. Evap really is just to prevent evaporated gas from escaping into the atmosphere, purely a non-engine related emissions thing. And the charcoal is just a filter in that system. But I will advise that you should do something with the line heading back to it. While there is not a ton of vacuum, there is indeed some as the fuel tank empties. So right now you have a port open to moist air, water (rain), etc... And as for that aforementioned charcoal canister? Meh... it can probably get soaked and not cause any issue really. Just a tased evaporations system at worst. But I dont see any other damages like something to the engine itself.
But to circle back, if you had an evaporations code before and you had lean issue, sounds like you had an evaporations system leak and that is something to maybe look into anyway if not the fuel cap. Because if you go through deep water with the rig, you may have an entry point for it right into the fuel tank.
