P1807-00 Four-wheel drive high ratio - short circuit to ground
Old Jan 29, 2024 | 10:09 AM
Hydronaut's Avatar
Default P1807-00 Four-wheel drive high ratio - short circuit to ground
Hopefully somebody can point me in the right direction. Literally down to 3 codes now. Driver seat heater, cruise control, and this.
I looked at the wiring diagram and tested pin 20 on the switch which reads 12 volts (14+ when running). Not sure what other leads I should be testing.
I have read some other posts where it ended up being the switch. Is there a process to test this outside of switching it with another?
I grabbed another switch piece as the shifter portion had a bunch of broken clips so will swap to see. never know.
Any help appreciated.
GavinC
Yesterday 11:37 PM
millermagic
May 28, 2023 07:36 AM
Andrew kiwi
Aug 10, 2020 02:47 AM
Geo
Jul 6, 2019 09:24 PM
Alphamale
May 3, 2015 09:35 PM
