Parking Brake Troubles C1A55-64
Old Apr 13, 2023 | 09:15 AM
Cziggy's Avatar
Default Parking Brake Troubles C1A55-64
So I've been having a parking brake issues for a while and I took it to local shop which replaced the shoes but couldn't clear the Parking Brake light on the dash. Went home and was able to actuate the parking brake without issues a couple times. And then of course I get a Parking Brake Fault on the dash with the following error
C1A55-64 (FB) Ignition switch input circuit - Algorithm based failure - signal plausibility failure
This one is a new one Im not sure where to begin. Any help or suggestions would be appreciated. I tried clearing the faults but it returns
Old Apr 13, 2023 | 09:48 AM
houm_wa's Avatar
What else does it do besides the fault? Noises? Vibrations? Does the EPB actuate and release correctly?
Old Apr 13, 2023 | 09:59 AM
Cziggy's Avatar
I get the following
Start the vehicle - Parking Brake Fault message and amber light
Vehicle in Park (Engine Running), try to apply parking brake - No noise only Parking Brake Fault message
Vehicle in Park (Engine Running), foot on brake and apply parking brake - I can hear the parking brake actuate, red parking brake light on dash and will hold vehicle if put into drive/reverse
Vehicle in Park (Engine Running), foot on brake and remove parking brake - I can hear the parking brake actuate, parking brake light goes out and parking brake is released
Turn off vehicle - Parking Brake Fault message
Old Apr 13, 2023 | 10:05 AM
Cziggy's Avatar
In case anything is related, here are the other faults Im gettingL319 - LR3 2005
Vehicle scanned on 13-04-2023 08:33
Using IIDTool BT V3.0 B2481
Parking Brake
  • C1A55-64 (FB) Ignition switch input circuit - Algorithm based failure - signal plausibility failure
    ( on 13-04-2023 08:33:08 at 260602 km )
Transfer Case
  • P173E-00 (2F) Ignition key lock solenoid - circuit low
    ( on 13-04-2023 08:33:11 at 260602 km )
Ventilation
  • B1B70-15 (2F) Local interconnection network bus circuit 2 - General electrical failure - circuit short to battery or open
    ( on 13-04-2023 08:33:09 at 260602 km )
  • B1B70-88 (2F) Local interconnection network bus circuit 2 - Bus signal/message failure - bus is off
  • B1B82-00 (2F) Rear air distribution stepper actuator
  • B1B83-00 (2F) Rear air blend stepper actuator
The rear blower/hvac hasnt worked in ages and Im not overly concerned right now
Old Apr 13, 2023 | 03:52 PM
houm_wa's Avatar
Hmmm....not sure, doesn't sound like an actuator though.
Old Apr 14, 2023 | 05:58 PM
Cziggy's Avatar
Big ask, can some one pretty please with a GAP IID tool capture the following line values while applying the parking brake and then releasing it and log this data to a csv file.
Main engine control module voltage supply (V)
Motor current (A)
Electric parking brake - switch input status (-)
Longitudinal accelerometer sensor input (ms2)
All of these IO values would be found under the Parking Brake section. I would love to compare anyone with an LR3 and LR4 to what I captured
toofaroffroad
Jun 13, 2022 05:28 PM
rlj174
Jan 11, 2022 06:57 PM
LR2driver
LR2
Jan 9, 2022 07:48 AM
twcord
Sep 30, 2021 08:17 AM
jmartosella
Range Rover Evoque
Dec 26, 2020 07:10 PM
