Please don’t hate on me… air ride advice.
Old Jan 13, 2023 | 03:45 PM
  #21
Koolminx's Avatar
Ok guys, he bought a reader. Here’s the results, But I see nothing in those results that would shut off the air compressor for the ride system after 15 to 20 seconds
any further thoughts?
Old Jan 13, 2023 | 03:47 PM
  #22
Koolminx's Avatar
Apparently he wasn’t done sending me screenshots. There are two more coats and 1 have to do with power to the rear sensors.
Old Jan 13, 2023 | 06:00 PM
  #23
houm_wa's Avatar
Is that from a $30 generic code reader from Autozone? Not to be a dick, but that isn't going to be helpful at all. You need the actual codes and fault descriptions.
Old Jan 13, 2023 | 07:51 PM
  #24
Koolminx's Avatar
He bought this one: The Autel AP200 is supposed to be a good option per the Disco3.co.uk forums.
Old Jan 13, 2023 | 07:52 PM
  #25
Koolminx's Avatar
He’s going to bring the car over tomorrow with his code reader, and I’m gonna go through his computer system via Bluetooth and see if I can get them live data off of it. He’s kind of electronically retarded so I have to give him a little extra helping hand now and then.
Old Jan 13, 2023 | 07:58 PM
  #26
houm_wa's Avatar
The Autel seems to be generic. Maybe the forum provided it as a "cheap alternative" or something...but in the end, there really only a few viable tools.
Old Jan 13, 2023 | 08:35 PM
  #27
Koolminx's Avatar
I’ll be using it tomorrow and see how I’m depth it this scanner will go.
Old Jan 14, 2023 | 01:53 PM
  #28
tracyc's Avatar
The AP200 will read the codes just fine. But again, you may have to read the air suspension codes when you have an actual fault. You haven't shown any suspension fault codes so far. And codes are just one part of a diagnostic.
Review LRTime's recent video on YouTube where they go over diagnosing a suspension leak. Also, just because something was replaced recently, don't assume it's still good. You need to follow a logical diagnostic process - throwing parts at this system will likely lead to frustration, not necessarily a fix.
Old Jan 14, 2023 | 05:04 PM
  #29
Koolminx's Avatar
I’m only his hands and replace what he asks because he’s got back issues.
im going to use that scanner and get into monitors while running and the like.
there isn’t a leak, there’s something shutting off the new pump after fifteen or so seconds.
Old Jan 15, 2023 | 12:15 AM
  #30
Coldwater's Avatar
The air suspension system is relatively simple. There are only a few comments to consider when going through the process of elimination.
- hoses
- hose connections
- valve blocks
- suspension
- reservoir
- pump
- sensors
- electrical
- ECU
Most of these can be tested for malfunction with soapy water. The others will most likely need to be replaced or an ECU update or suspension calibration.
A good code reader like the Gap tool would help you diagnose this in depth.
