Power Seat Button Not Working? Easy Fix
Old Mar 7, 2022 | 11:43 AM
RickyN29's Avatar
Default Power Seat Button Not Working? Easy Fix
Hello,
My LR3 driver seat stopped going back but would move forward. A replacement switch assembly is quite expensive so I took mine apart and wanted to share that it is an easy fix. The contacts get carbon build up from arcing and you simply clean them up with a little sand paper and reassemble. You do not need to unplug the switch from underneath, there is enough cable slack to just work on it right there. Here are some pictures so you can see the details. 30 minutes saves the $250 replacement cost.
You need to pry open the PCB switches to get at the contacts.
The black you see circled is the carbon build up. I metered the switch and it was not making contact. Little sand paper and good as new!
Old Apr 16, 2023 | 10:55 PM
RescueDog1's Avatar
How did you get the switch out? Mines completely dead and the fuse is good. I ordered a used switch but a little hesitant on how to take it out.
Old Apr 16, 2023 | 11:42 PM
RickyN29's Avatar
I did the fix while still connected. If I remember, I couldn’t see an easy way to unplug to remove so I was happy I had slack to fix in place.
Old Apr 17, 2023 | 11:45 AM
RescueDog1's Avatar
Does the plastic holding the switch pop out of the bottom trim piece?
Old May 26, 2023 | 03:33 PM
RescueDog1's Avatar
The switch is screwed into it if I remember. Im having this same problem. Ordered a used switch and still nothing. I might have to look closer at the stock one. My fuse is good also. My tech had mentioned the motor might have failed, but don’t know how to check that out.
Old Jun 30, 2024 | 09:27 AM
DryFly Trout's Avatar
Any more info in this one? Specifically about removing the switch/ plastic piece it's attached to? Thanks.
Ulrich453
Mar 25, 2019 03:22 PM
flacsrover
Sep 7, 2010 02:05 PM
alphawolfman
Oct 19, 2009 01:20 PM
bladerover
Dec 10, 2008 11:06 AM
discoken
Sep 11, 2007 07:49 PM
