Power Steering Pump rear bolt hell
Old 04-25-2022, 02:55 PM
P-Bod's Avatar
I do believe I removed the power steering pump first, so yes I think you can get to it without removing the compressor. I think I used a ratchet wrench and a ton of patience for each click.
The following 2 users liked this post by P-Bod:
cokeeffe (04-08-2023), gustavohuber (04-25-2022)
Old 04-25-2022, 02:58 PM
tracyc's Avatar
No need to move the ac. You can get to it going over the top of the pump through the splash shield area.
The following 2 users liked this post by tracyc:
Old 05-01-2022, 12:27 AM
gustavohuber's Avatar
Hooooooly hell. That was unpleasant, but it's done. I was unable to figure out how to get a decent angle onto the upper bracket bolt, but with the wheel removed and a little more elevation off the ground, I was able to painfully unscrew the rear pump bolts about 3º at a time (after accidentally breaking the plastic mount for the transmission cooler hard lines), by reaching through the left side splash guard, using a ratcheting 10mm box end. If I ever have to do this again (please, no.) I'll spring for either a stubby ratcheting box end, which will be able to get more rotation in before hitting the hard lines, or I'll get some magic long-reach, low-profile electric ratchet handle that probably costs as much as having a shop do the pump for me.
Thanks all for the suggestions and photos, I would have gone nuts without your help.
The following 2 users liked this post by gustavohuber:
cokeeffe (04-08-2023), P-Bod (05-01-2022)
Old 05-01-2022, 03:46 AM
tracyc's Avatar
Congrats! A stubby rachet or a flex head stubby would help a lot in there. I forget what combo of extensions, ujoints and flex head wrench I used to get at that upper bracket bolt
cokeeffe (04-08-2023), gustavohuber (05-11-2022)
Brandon318
06-25-2022 06:26 PM
Hercu
03-09-2015 07:48 AM
james.martin1
09-30-2014 06:33 AM
120proof
12-28-2013 03:56 AM
pkunze
02-11-2013 06:49 PM
Quick Reply: Power Steering Pump rear bolt hell
