Power Steering Squeal
Old May 31, 2014 | 01:01 PM
Will Swett's Avatar
3rd Gear
Default Power Steering Squeal
Happy Saturday! I have an 05 LR3 with just over 100k on it.
Took it to my very reputable indie rover mechanic for an oil change. They noted the power steering fluid needed changed.
I changed the fluid as per the RAVE manual instructions. Except, I pulled the low pressure line vs using the drain plug.
That was probably my mistake. But, I followed the bleeding instructions to a tee.
All seemed fine until the next day. Fired him up, and it started squealing like nothing else.
So, I repeated the process with fresh oil, thinking I'd dislodged some crud while changing. That took care of it.... for about 48 hours. I don't see any leaks.
Am I missing something obvious? One thing I did notice: there was no oring on the l/p line. Should there be one? The manual did mention removing it.
DiscoBritney
Dec 19, 2011 06:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
boxerboy2
Aug 26, 2011 03:42 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
