Power Steering Squeal
Old Aug 19, 2011 | 11:26 AM
boxerboy2's Avatar
Default Power Steering Squeal
When I first start up my '03 DII, the power steering pump will give me a squeal. This has started to occur after I changed out the PS fluid. Is their a way to bleed the system?
Suggestions...
Thanking everyone in advance.
Old Aug 19, 2011 | 02:20 PM
What fluid did you install? Have you inspected and replaced your belt? How many miles on the pump?
Old Aug 19, 2011 | 08:05 PM
There is a nut ontop of the steering box, with the engine idling loosen that nut a turn or so, fluid should come out.
That is the bleeder screw.
Old Aug 19, 2011 | 08:44 PM
0304Disco's Avatar
I've had my pump off, rebuilt the pump and changed the lines and never had to bleed the system. I run Lucus power steering fluid in both my Discos and have no problems.
Old Aug 19, 2011 | 08:51 PM
I would want a helper to start the truck, while someone with sharp eyes watches the pump pulley - is it binding or frozen during the squeal (if the squeal is the serpantine belt)? Or is it something else on that same belt, like water pump, Ac compressor clutch, idler tensioner pulley, etc.?
Old Aug 20, 2011 | 09:10 AM
I am still waiting to see if it is his belt or bad tensioner as well as the fluid he used.
Air in the system will not cause a first start in the morning squeal.
Old Aug 26, 2011 | 03:40 PM
boxerboy2's Avatar
Sorry for the lack of a response...I've been out of town for the last week or so.
As far a fluid goies it was something other than Lucas. The pump has 110,000 on it,. It is definately not a belt slipping although I'll check that when I bleed the system this weekend.
The squeel
Old Aug 26, 2011 | 03:42 PM
boxerboy2's Avatar
as I was saying... the squeel occurs when the stearing wheel is turned for the first time on after starting the motor, NO when the engine is first started.
Thanks again for everyones help!
Will Swett
May 31, 2014 01:01 PM
DiscoBritney
Dec 19, 2011 06:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
