Pulled the EAS fuse
Old Mar 11, 2017 | 11:00 PM
outdoorsdad's Avatar
Default Pulled the EAS fuse
I found my08 to be lower on the passenger side on a few occasions so I tested for leaks by pulling the fuses. Is llosing about an inch of height after letting the truck sit for 36-48 hours (on all corners except the driver side rear which didn't lose any height) anything to be concerned about?
Old Mar 13, 2017 | 09:56 AM
DavC's Avatar
To clarify: which fuse did you pull?
Old Mar 13, 2017 | 10:05 AM
Actually, I pulled the two fuses and the 1 relay that we're in the fuse box and showed the suspension picture (can't remember the numbers off the top of my head).
Old Mar 13, 2017 | 10:09 AM
DavC's Avatar
The only one that really matters is F26E
Make sure that's the one you pulled. 36-48 hours isn't the worst, if a whole axle drops it is likely the valve block for that axle, if it's a corner, likely between the valve block and that strut assembly. Sometimes lines or fittings get pinhole leaks.
Old Mar 13, 2017 | 01:46 PM
djkronik57's Avatar
Would fuse F3E also work? F3E gets its power through F26E.
Old Mar 13, 2017 | 03:26 PM
I pulled both the F3E and the F26E. Pulled both because I wasn't sure which one so I figured pulling both wouldn't hurt. I have the valve block seal kits but I guess for the time being, I will just keep an eye on it and retest every couple of weeks to see if the air loss increases.
Blakesrover
Feb 21, 2013 01:43 AM
rayrap
Dec 19, 2010 04:27 PM
simjack
Oct 12, 2008 10:24 AM
cold_surfer
Feb 6, 2008 06:30 PM
disco12
Mar 19, 2006 03:48 AM
