Quick Height Rod Question
Old May 26, 2015 | 11:15 AM
mx468's Avatar
Default Quick Height Rod Question
So just wanted to ask when using liftt rods that raise your truck 2.5" and you get the suspension fault and the truck lowers, or if you choose access height manually, does your truck go down to actual access height or is it going back down to stock height. 2.5" lower? Not all the way to the bump stops? Thanks.
Old May 26, 2015 | 11:27 AM
morrisdl's Avatar
Short rods raise all three settings (access normal and Offroad) up 2 inches. Faults that drop the the bump stops is still the same level.
houm_wa
Mar 31, 2016 12:57 AM
charles21
Feb 21, 2011 11:08 AM
icyhot201
Aug 16, 2010 07:24 PM
endneu913
Nov 3, 2007 03:46 PM
suntattoo80
Feb 14, 2007 09:25 PM
