Rear on bumpstops
Old Nov 11, 2015 | 12:37 PM
DavC's Avatar
Originally Posted by TOM R
Looks like my parts truck on the stops due to an air leak
I don't know bout you but our 05 when you shut it off after 30 seconds? Lowers some you can Hear the valves clicking and releasing air, start it up and it pops back up, seems odd but always does it
My 06 does the same, drops maybe a 10-20mm at rear when you get out and cut the engine. Had a LR tech tell me thats completely normal behavior. For whatever reason after I recalibrated the suspension I haven't had that happen yet... hmm
Old Nov 11, 2015 | 03:43 PM
houm_wa's Avatar
DJkronik, can't tell from the pic....but I agree if the camber looks off then that may be lower than Access. Access is pretty darn low too, though.
The only reason I'm picking on this is that I don't believe the LR3 will go to bumpstops without a corresponding alert/message.
Old Nov 11, 2015 | 04:18 PM
djkronik57's Avatar
No worries, that's what has me stumped as well. I'd think if it was an air leak, it would drop to the bump stops over time with nothing else to keep it up. Would that typically trigger a fault when it was next started up?
Old Nov 11, 2015 | 09:23 PM
houm_wa's Avatar
I would think so. I would think you'd get some kind of indication but I'm not sure. That's the one EAS issue I haven't had! (knock wood)
bcolins
Jun 22, 2013 08:55 PM
hilltoppersx
Dec 22, 2010 05:15 PM
ljdiscovery
May 22, 2008 10:30 AM
00discosd7
Dec 27, 2007 07:08 PM
01 Discovery
Dec 1, 2006 12:07 AM
