Rear A/C not blowing
Old Aug 9, 2013 | 04:39 PM
oljohnboy's Avatar
Default Rear A/C not blowing
Hi everyone,
This is an issue I inherited and Land Rover could not figure it out. When you turn the rear air on with rear control, everything activated and works except the fan. The fan has been tested and is good and the relays have been checked thereby stumping the dealership. Has anyone had an issue similar. Also the front air does the same thing periodically where you turn the **** and no fan. Turn it off and on and it will work and is worse in the winter. The relays under the hood are new. Anywhere else to look? It is an LR3!
Thank You!
Old Aug 9, 2013 | 09:02 PM
The rear air control has a module between it and the motor. That module has an earth ground. I'd check the ground, then the module. Schematic attached for the shop manual.
File Type: pdf
Old Aug 11, 2013 | 01:06 PM
oljohnboy's Avatar
Do you know the physical location?
JStephen
Feb 2, 2010 06:59 PM
johnkbl
Dec 29, 2008 11:15 AM
Damiean
Aug 22, 2007 01:34 PM
hkp
Sep 13, 2006 11:46 AM
