Rear Upper Control Arm
Old Oct 10, 2023 | 08:32 PM
  #21
houm_wa's Avatar
Yeah that's terrible....
Not to be a dick, but this is my frame.
Old Oct 10, 2023 | 08:33 PM
  #22
DakotaTravler's Avatar
That is 100% untouched original? Wish mine was that nice, but mine it at least still showing most of its paint. With that said, I would love to do a body-off restoration of the frame. And def repair the factory defect areas that collect water and debris.
Old Oct 10, 2023 | 09:19 PM
  #23
houm_wa's Avatar
It's original, from 2005....the only thing I do is sand/paint any surface rust from off-roading, like if I scrape paint off on a rock and rust forms (mostly sliders and gas tank skid, hardly any of that on the frame) and then spray it with BOESHIELD. I do that once a year.
Old Oct 10, 2023 | 09:22 PM
  #24
loanrangie's Avatar
I don't think ive seen a chassis that rusty even on a UK forum, i guess the other side would be just as bad so may need a chassis chop from a wreck to repair it or just do a body swap as DT has said.
Old Oct 31, 2024 | 06:22 PM
  #25
Ackrovers's Avatar
5th Gear
Default LR3 Frame Rust Repair
Originally Posted by Ackrovers
I know, right? @houm_wa it’s a shame…no off road experience. Check out some more frame rust. I want to now take body off frame, weld in new frame section, rebuild the upper and lower control arms, wheel, hub, brakes etc,, remove all rust and turn it into a fun overlander rig.
I was able to go after the rust shown and put a beefy patch in. Also fixed the control arms.
Solid frame again.
Solid frame again.
Old Nov 4, 2024 | 06:15 AM
  #26
x81's Avatar
x81
7th Gear
Originally Posted by houm_wa
How have you validated this? What are the physical symptoms?
My '05 has 135k miles and the rear uppers are fine. My '06 has 245k miles and while there is some "noise" coming from the rear suspension, nobody (at either dealer or indie) has stated that the rear uppers look shot. So, how have you determined this?
Thats impressive. I picked up my ‘06 at 123k. Both rear uppers and both front lowers were trashed. Rear uppers caused a bit of rear steer on curved freeway junctions. The truck would lean and trigger traction control. Putting it up on jack stands, you could grab the rear wheel and visibly rock it up and down.
Back to OPs question, I replaced mine in my driveway on jack stands. No need to lift the body. I will say that mine has also seen quite a bit of rust, and I had to cut the arm and the bolt as it was rusted to the inside of the bushing. But still nothing that needs to touch the body mounts.
Old Nov 5, 2024 | 06:42 PM
  #27
houm_wa's Avatar
I did finally change the rear upper on my '06, at about 252k....I was getting the rear wheel bearing changed in that corner anyway, so what the hell, right?
thorgal
Apr 1, 2019 02:58 PM
RickyN29
Jun 13, 2018 11:54 AM
AdrenalinPlease
Nov 20, 2017 10:32 PM
Zelatore
Jun 11, 2016 12:50 AM
demelvin
Jul 30, 2008 10:24 AM
