Rear Wiper Blade
Old Mar 27, 2018 | 05:00 PM
EastCoast's Avatar
Default Rear Wiper Blade
Is there a trick to removing the rear wiper blade? Because of the metal wiper arm shroud, I can't get a look to see if there's a tab or something I need to depress. I spent about 10-15 min with a small flat bladed screwdriver but only managed to break some of the plastic on the old wiper blade.
Thanx for any help on this...
Old Mar 27, 2018 | 09:01 PM
DakotaTravler's Avatar
Odd. Mine just pulls off towards the pivot point. New one snapped in place. Just like most other wipers I have replaced.
Old Mar 27, 2018 | 09:07 PM
OverRover's Avatar
Have a look at 2:45
Old Mar 28, 2018 | 11:00 AM
schwaggy's Avatar
While pressing the clip (if one), push harder than you think you should to the left (toward the pivot point). The angle has to be just right, too.
Old Mar 28, 2018 | 01:09 PM
Jagfixer's Avatar
I always remove arm to replace blade ( to prevent bending or braking something ). Easier on the bench.
Old Mar 28, 2018 | 04:21 PM
djkronik57's Avatar
I'd recommend this as well. Much easier to see what you are doing and get the right angle. It's just a bolt to remove.
Old Mar 28, 2018 | 05:35 PM
Geez, mine must have been worn in some way or never fully installed.
Old Apr 5, 2018 | 08:50 AM
EastCoast's Avatar
Thanx for the replies... gave it another go and managed to get it replaced. It did take a little more force than I initially thought. Replaced the old wiper with a Bosch Icon... such a nice difference. One of the things LR engineered right on our 3's was the rear window wiper path design.
bcolins
Feb 2, 2014 09:40 PM
photocrimes
May 17, 2013 09:34 AM
JAC
May 9, 2010 04:35 PM
vmann7
Jun 6, 2009 01:12 PM
bigugly82
Apr 4, 2007 06:30 PM
