Reduced Performance Following Alternator/Battery Replacement
Old Jul 27, 2016 | 03:50 PM
WoCoLR3's Avatar
Default Reduced Performance Following Alternator/Battery Replacement
Hello all!
Last week I replaced the alternator on my 2006 LR3 SE V8 as it completely died on me. Following the successful replacement of the alternator (remanufactured Denso unit) I realized the battery was shot and replaced it as well.
The vehicle starts up as it should and drives without much issue for a bit. I then begin to notice that the battery light turns on and off randomly while driving.
In addition to the previous issue I have noticed that it seems to take a good bit more effort for the vehicle to accelerate from a dead stop. Once I get to my cruising speed the vehicle performs as it should and at normal RPM.
I have not seen any fault or error codes following the replacement other than the red battery light.
I have seen other posts saying that it could be a faulty replacement alternator, but have not heard anyone mention intermittent reduced performance or battery light.
Does anyone have any insight to the cause of this issue. I feel it is most likely a bad alternator, but want to make sure its not something even more simple that I have not encountered on other forums.
Thank you for you assistance in advance!
Old Jul 28, 2016 | 11:14 AM
houm_wa's Avatar
I am not familiar with the Denso units. I would've used an OE part in that case. I use non-OE for obvious things: tires, battery, light bulbs (although that one is not-so-obvious) and for the acceleration thing, try driving it really hard for a while and see if your transmission doesn't adapt. On the flip side you could try resetting the adaptations and seeing if that doesn't help.
Sorry I can't be of more help.
Old Jul 28, 2016 | 07:25 PM
EastCoast's Avatar
Did you change out your belt or just the alternator? I would think, if the belt is slipping, it would throw the battery light and possibly limit engine performance for safety?
Is there any chance, where it's a reman'd unit, that the pulley is a different dia. than what came off? If it was smaller and your ran the limit on your tensioner, it would tend to slip.
Just some random thoughts...
Sanriogonz
May 23, 2012 11:27 PM
Johntom
Nov 20, 2011 03:27 PM
dmccoig
Jul 18, 2011 07:33 PM
JakeHalliday
Feb 23, 2011 10:54 PM
Albert Frederik
LR2
Jan 17, 2011 11:07 AM
