Replacement key fob
Old Jun 1, 2014 | 09:07 AM
mirepoixmatt's Avatar
Default Replacement key fob
I've searched the forums and it all leads back to : take it to dealer.
Is this as good as it seems?
Old Jun 1, 2014 | 08:58 PM
bbyer's Avatar
Default It's a miracle!
Well, it must be possible so probably the video is for real. The only questions I ask are where did the new key blade appear from and more importantly, the key fob.
Cutting the key blade can be a bit of a trick but I know it can be done with the correct blank and a proper machine.
As to the key fob, I have difficulty believing that any easy to get and cheap printed circuit board of the correct frequency will work. It should be possible I guess, but again where?
Then there is the question of how much does the programmer cost? The economics of acquiring all the items may not make sense for a single owner to purchase same.
Old Jun 1, 2014 | 09:14 PM
bbyer's Avatar
Default about $300 to purchase
I checked the website out and it appears the low cost programmer costs about three hundred US dollars; the one size fits all programmer, eight hundred.
Also, the unit may not work for model year 2005 as it suggests 2006 to 2013 3's and 4's - but that may be a typo.
SuperOBD key programmer manufacturer
Old Jun 2, 2014 | 12:05 PM
jafir's Avatar
Bruce,
I asked about key/remotes on the nanocom or maybe AULRO forum a few months ago. It's on their list. They said it would be pretty simple to code since they've already got the routine for their MSV-2.
http://www.aulro.com/afvb/electronic...ml#post2023097
Old Jun 2, 2014 | 06:51 PM
bbyer's Avatar
Default less of a mystery now it appears
I guess I have not been keeping up with advances in key cloning.
I did not realize that the key software was even on the horizon as far as the Nanocom was concerned; it is something to look forward to as going thru the dealer is not the most fun experience.
Thanks for the heads up.
NiteTrain
Jul 5, 2013 11:04 AM
Discolife
Nov 25, 2011 11:38 AM
pilsner
Apr 7, 2008 03:24 PM
bduke
Off Topic
May 5, 2007 12:29 AM
Jay
Apr 27, 2005 03:49 PM
