Rpm fluctuates and stalling when idling but capacitor discontinued?
Old Apr 1, 2024 | 10:54 PM
Gizzyg55's Avatar
6th Gear
Originally Posted by CantComplain
If you haven't inspected and/or cleaned the throttle body yet, that would be my next step. See https://www.youtube.com/watch?v=1cX0pCJbapk or any number of other TB cleaning vides, I just happen to like this guy. This particular video doesn't go into great detail on the actual cleaning but once you're staring down the barrel of it, gently open the "butterfly" and use a solvent (such as throttle body cleaner) to clean the plate on both sides, the edge/circumference of the plate, and the barrel where the plate closes on it. You can get down the barrel too, but just don't scratch it with a tool--use a clean rag or paper towels. If it's chunky, that's a good indicator it's letting in extra air and could be causing your issues. Take your time, use a toothbrush, wipe it all out.
If you go slow, it will take an hour and cost $10 if you use name brand TB cleaner. And it's well worth it even if it doesn't solve your problem.
Thank you for the info, I just finished cleaning my throttle body before jumping the wires for the capacitor and it fixed the issue!! Dont know how I forgot to check that after cleaning the maf sensor. It had a lot of carbon build up and after taking my time cleaning I let it idle and fixed my issue! Appreciate all the help and info that was provided!
Stuart_B_S
Nov 16, 2023 11:37 AM
AndrewGr
May 6, 2023 03:33 PM
Mario Saavedra
Nov 29, 2013 08:52 AM
joncampbell21
Jan 8, 2009 10:01 AM
DMoore
Nov 4, 2008 11:35 AM
