Search came up empty....
Old Mar 23, 2023 | 08:46 PM
houm_wa's Avatar
Default Search came up empty....
...but I know I've seen this.
P0442-00, Evaporative Emission System leak detected along with "loose or missing fuel cap." I've done the usual things. Removed it, tightened it, etc. I cleared the fault and we will see if it comes back.
in the meantime the filter neck doesn't look quite the same as the one on my '05. Anyone else's look like this?
Thanks all!
-Houm
Old Mar 24, 2023 | 09:40 AM
Rufflyer's Avatar
Default Yes and No
I do have a problem with 2006 & 2014 not filling complety, but only the 2014 shows a code for EVAP leak I have yet to find. ( I put more smoke in that thing than they use in KISS concert and still nothing found)
From my 2006
From my 2008
I am curious what you find.
Jeff
Old Mar 24, 2023 | 10:57 AM
houm_wa's Avatar
My '05 looks more like your 2nd photo.
Old Mar 24, 2023 | 06:44 PM
DakotaTravler's Avatar
I am pretty sure that is a flap and on mine it gets stuck open sometimes. But its job is not to seal, it is to slow fuel from pouring out in an accident/rollover.
Old Mar 24, 2023 | 07:11 PM
houm_wa's Avatar
Okay so that isn't part of the issue.
....it seems to have gone away, though, after I added more fuel. Could it have been a fuel quality issue? I've seen it in the past, too, only to have it self-correct.
Old Mar 25, 2023 | 12:22 AM
Could be. Or defective filler cap. They do wear out or fail.
Old Mar 25, 2023 | 12:38 AM
houm_wa's Avatar
Right....could be that, but my error seems to have gone away after filling back up with fuel from a new spot. At the same time, a buddy of mine had his LR3 throw the same error. The common denominator? We both usually get fuel at Costco! I'm betting on some bad gas from their supplier. I'll keep an eye on it; thanks y'all!
Old Apr 3, 2023 | 12:57 PM
wichipong's Avatar
is the fuel flange recall only for LR4s? or LR3s included?
Old Apr 3, 2023 | 06:28 PM
houm_wa's Avatar
Fuel Flange recall???
Old Apr 3, 2023 | 07:56 PM
wichipong's Avatar
i looked it up.. only from 2010 - 2016 lr4
'BamaBoy
Sep 15, 2023 02:29 AM
navyblu3
Range Rover P38 (2nd Gen)
Sep 7, 2022 11:30 AM
cmb6s
Oct 3, 2017 10:16 AM
lilredpo
Aug 28, 2013 09:47 PM
georgetrieste
Feb 6, 2008 09:15 AM
