"Select Neutral for Range Change" message
Old Nov 14, 2019 | 05:06 PM
cybercop's Avatar
Default "Select Neutral for Range Change" message
Daughter is driving the LR3 and said she is getting this message.
She says it makes a beep noise and then the message pops up.
I'm thinking she changed the range dial. She is going to check.
If not, any other things that can cause this?
Old Nov 14, 2019 | 06:45 PM
Only thing I know of is switching from high/low range on the transfer case that causes this.
Only time I get the message is when I hit the lever when I’m still in gear. It hung around one time so I went back to neutral and cycled it back to low than into high. That cleared it
Old Nov 14, 2019 | 06:58 PM
LR Techniker's Avatar
That message usually involves "Lo Range" on the transfer case. So either the T/Case switch is getting bumped or its shorting out (spilled fluids, left open sunroof, etc...)
Old Nov 14, 2019 | 08:43 PM
houm_wa's Avatar
OR....if she tries to select Rock Crawl maybe while driving???
Since Rock Crawl requires you to be in Lo Range.
Old Nov 15, 2019 | 03:12 PM
cybercop's Avatar
Ok, so the "select neutral before range change" went away before she got me the truck. Now, when ever the truck starts off it is getting the "HDC fault system not available" message. And it is consistent.
Related?
Old Nov 15, 2019 | 04:01 PM
Check where the terrain response dial is pointed to out of curiosity
Old Nov 15, 2019 | 04:40 PM
cybercop's Avatar
It was all the way to the left, on Normal
Old Nov 18, 2019 | 05:30 PM
Alex J's Avatar
I would try putting it in rock crawl on the terrain dial, put the trans in N, select low, drive it a few yards in a strait line then put it back to standard mode on the dial and put the t-case back in high range. Sounds like the dial or the t-case lever was messed with and now something is out of sync. It probably also wouldn't hurt to turn HDC off and back on while in rock crawl mode. If that doesn't take care of it it might be worth it to spend the money on a half hour of diag at a shop that can properly pull Land Rover faults.
dwatterson1
Feb 27, 2017 09:35 AM
IvanC55
Nov 12, 2014 05:55 PM
95_rover
Dec 6, 2012 07:47 PM
NAGA
Nov 12, 2010 02:55 PM
LRadventure
Sep 25, 2010 10:50 PM
