Shifter issues
Old Feb 1, 2021 | 08:47 PM
loanrangie's Avatar
Default Shifter issues
Ever since my mini top end rebuild ive had some issues with D being illuminated regardless of the gear its in and sports mode not working. Are these 2 functions controlled by switches under the console or on the shifter itself ?
The correct gear is shown on the dash.
Old Feb 7, 2021 | 01:36 AM
Globetrotter448's Avatar
The connector under the switch can give problems but I would check the shifter linkage on the side of the gearbox as it tends to rust up. Remove and clean and see how you go as this is a cheap fix.
Old Feb 7, 2021 | 05:47 AM
loanrangie's Avatar
Not mechanical so not the shifter linkage, could be switches so i'll need to pull the console and check the connections.
Old Feb 10, 2021 | 09:32 PM
loanrangie's Avatar
Looks like i found my answer in the general tech section, shifter needs to be replaced which is pretty much the conclusion i have come to.
https://landroverforums.com/forum/ge...52/#post760975
Old Feb 13, 2021 | 05:11 PM
loanrangie's Avatar
Replaced the shifter and short loom it connects to and all fixed.
Ghaniba
May 4, 2024 10:06 PM
Bal D Correa
Apr 24, 2020 04:31 PM
LR3inCanada
LR4
Sep 12, 2015 10:26 AM
archaeology_student
Feb 7, 2015 04:02 PM
microbc
Nov 23, 2011 01:54 PM
