Shifter stuck in PARK
Old Apr 23, 2024 | 07:06 PM
loanrangie's Avatar
Originally Posted by TripleF_67
Okay . . . things have gotten a little more complicated. My wife took my car to her house (50 miles away) so I could work on her LR3. I needed to go to the grocery store so I hopped in the LR3 and started driving! Then is when I realized the truck will not shift out of first gear! And to complicate things even more the nearest Rover shop is 2 hours away driving 50 mph (~3,000 rpms).
Is there anyway to bypass this transmission fault limitation? I have exhausted everything I can do and I need to take it to someone that knows way more than me and has a shop with tools!!!
You can try a hard reset but it will likely come back once you try to drive it, sounds like you have a serious trans problem as limp mode locks you into 3rd which still makes it driveable.
Old Apr 24, 2024 | 02:04 PM
DakotaTravler's Avatar
loanrangie asked if shifter gear position matches what is shown on dash - does it? Did you try manual selecting gears (sport mode)? Maybe asked, but do you have any fluid leaks? If the mechatronics sleeve fails and gets soaked with trans fluid, I have heard of issues. Also being stuck in a gear can likewise be a sign of low fluid although usually you get a lot of engine flaring too....
Old Apr 19, 2025 | 02:45 PM
lr3/4's Avatar
did you solve the problem? if yes, what was the route causes of it?
dmenchaca1966
Jul 12, 2021 09:44 AM
suzukisam
Mar 27, 2020 06:55 PM
rmace1
Jan 16, 2012 08:27 PM
dustin1977
Mar 24, 2009 11:19 AM
cstocks
Jan 17, 2009 10:43 AM
