Slight transfer case leak, question.
Old Jan 9, 2021 | 10:31 PM
Pfeffer's Avatar
8th Gear
Thank you for your response (and I figured this was the correct place to post it).
I am 100% sure it is coming out of the hose...I do not need to add an extension to make sure of that. Though, it will help in diverting the mess.
Old Jan 9, 2021 | 10:39 PM
DakotaTravler's Avatar
It just would be really odd. The fluid level is not even half the case capacity. To give you an idea, here is the transfer case. The line I made for fluid fill is actually a little high. You can see the fill plug the left. On top is the breather, just behind that flange.
Old Jan 16, 2021 | 09:58 AM
Pfeffer's Avatar
8th Gear
Interesting when you draw up that example. Going to run hose this weekend and see what I can figure out.
Any possibility it's getting very very hot?
Old Jan 17, 2021 | 09:31 PM
I am pretty sure there is a temp sensor within the setup, could be wrong. But if there is one and it gets too hot it would trip a "transmission too hot" message. And while it does have clutches, it would take a low fluid situation to really get it to overheat I would think.
bhowell450@gmail.com
Jul 30, 2017 01:44 AM
cheapjeep2
Aug 23, 2015 08:58 PM
hilltoppersx
Aug 26, 2010 06:47 AM
Chrisinhouston
Aug 17, 2009 11:51 AM
Tapper
Feb 3, 2009 09:35 AM
