Intermittent crank but no start problem (06 V6)
2006 LR3 V6 gasoline engine
153K miles
I have been plagued with an intermittent no-start issue for a while.
I thought this was an issue with the evap pump but today, the gas tank was full and it did not start.
this can happen minutes or days after the truck sitting with the engine off. Most of the time, this is hours after running.
once started, it will restart without hesitation.
Symptoms:
- randomly will not start
- engine cranks
Additional data:
- did not start yesterday morning either
- today was cold (35 Farenheit) but temperature does not seem a factor (I.e. not a battery issue?)
- humidity level does not seem to make a difference (today is very dry)
- will always start with starter fluid injected on air intake side
- 153K miles
- air filter clean
- no code thrown
- noise heard when turning key in position 2 from the tank/fuel pump area (no idea if noise heard is appropriate)
- IID tool reports:
- fuel rail temp stuck at -40 Celsius
Happy to report on live values from IID Gap tool if that helps.
153K miles
Symptoms:
- engine cranks
Additional data:
- 153K miles
- air filter clean
- no code thrown
- IID tool reports:
"fuel rail temp stuck at -40 Celsius" My 4.0L reads the same, so I doubt that is an issue.
Have you tried to cycle the key a few times to the second position, wait a few seconds and then back to off? If it fires reliably on starting fluid, it sounds like it has a fuel delivery problem. The key on-wait-off-repeat procedure may help to build fuel pressure if your pump is weak. Listen for changes in the pump priming sound as you cycle the key. If your pump is weak, you may hear it trying to build pressure. Otherwise, if your pump is operating properly, you probably wouldn't notice the pump building pressure before the engine starts.
Does it stumble or run rough after it starts?
i can hear the pump run. I have not yet (its cold now!
) figures out where the shradder valve is to check fuel pressure. I did not try the position II a few times yet. Will try this next time it does not start. Also, never say never, but from what I read on the topic the sensor tends to die/misbehave with higher temperature and the issue disappears when engine is cold(er). Ill still look for known issues like this with the Ford engine!
runs great after it starts. No stumbling or rough running.
) figures out where the shradder valve is to check fuel pressure. I did not try the position II a few times yet. Will try this next time it does not start.Thread
Shryan
Jun 27, 2008 08:33 PM
