Squeak from rear suspension.
Old May 26, 2022 | 04:14 PM
DakotaTravler's Avatar
Why would you not use new ones? If top are new OEM, then check the bottoms maybe. Next step may be to load the rear bags of air and manually manipulate everything to locate for sure. Any oil works, don't need a lot just enough to lubricate. Do both sides of the joint.
Old May 26, 2022 | 04:19 PM
Oceanguy33's Avatar
No no...what i'm saying is that there are new top joints in - they are Lemfoerders...and that i shouldn't bother with them because they are new...or should I?
Old May 26, 2022 | 04:21 PM
If new, leave em alone. Bottoms ones, if old, lubricate by injecting oil into the rubber boot on each end then seal the injection point so water can not get in.
spanishfly
Mar 15, 2015 11:33 AM
Alyssa Bauman
Dec 16, 2013 08:49 AM
DiscoMeadows
Jan 2, 2012 05:23 PM
superdiscovery
Aug 10, 2011 08:35 AM
Firsty
Feb 22, 2008 08:00 AM
