Stalling Intermittently
Old Feb 16, 2019 | 05:36 PM
vanbadri's Avatar
Default Stalling Intermittently
My stalling problem resurfaced today after almost a month of perfect operation. Car was driving fine all day, then I started it up and pulled out of the driveway, accelerated to maybe 20 mph, and it died. I pulled over, tried to start it, and it’ll start just fine, rev up as it starts, and then drop down and die. Did that maybe 5 times, then started and stayed, so I limped back to my driveway.
I’m beyond frustration with this. It has a new throttle body, EGR valve, battery, brake light switch, and a fresh injection cleaning. The fuel pressure is also normal. WHAT could possibly cause such a problem to occur so intermittently?
Old Feb 16, 2019 | 10:50 PM
DakotaTravler's Avatar
Have you monitored fuel pressure while this stall happens?
Old Feb 17, 2019 | 06:48 AM
vanbadri's Avatar
Unfortunately no, it’s so intermittent that I can never get a pressure gauge on it while it’s happening. The car was completely fine for a month, never showed the slightest hesitation. Then this. I know it could be a fuel pump.
I popped my IID on last night and got a P0513 Incorrect Immobilizer Key. I’d never gotten that code before when this problem happened. Could the immobilizer cause a problem once the car is already started and driving?
Old Feb 18, 2019 | 01:53 PM
abran's Avatar
Immobilizer won't cause that. Thats a "Fake" code which comes up time to time.
Sounds like fuel pressure of could be throttle body
Old Feb 18, 2019 | 05:09 PM
vanbadri's Avatar
thank you! Didn’t know this, good to know that’s a code I should ignore, because apparently there’s a lot of them baha.
sdhphoto
Jul 24, 2018 06:42 PM
filthydisco01
Oct 26, 2016 09:11 PM
bobm
Mar 5, 2012 07:13 PM
Kandow
Aug 19, 2009 05:46 PM
rravenn13
Aug 4, 2007 06:33 PM
