Stang problem
Old Mar 23, 2024 | 10:58 AM
Dameontheman's Avatar
Default Stang problem
06 LR3 HSE
I have a strange problem, my passenger door open, interior light and the orange light on the outside of the door cycle on and off. On for 7 seconds, then off for 22.5 seconds. It does it constantly and never stops so long as the key is on. The window motor also isn't working. I ordered another window motor off of ebay and it isn't working either. During the 7 seconds the lights are on the window motor doesn't even receive the signal to roll the window up or down. When they are off it tries to turn but can't. When I push the window button and it tries to turn the orange exterior light will come on like the window switch is a light switch. Any insights????
Old Mar 23, 2024 | 08:09 PM
CantComplain's Avatar
Since it's the passenger side, it's worth checking whether the carpet in the passenger side is wet, or has been wet in the past. There's a large bundle of wires in the footwell on the passenger side and there are common reports of electrical issues when it gets wet. Leaks from the A-pillar or more commonly the sunroof can cause this. The main electrical junction box is directly behind the glove compartment.
If there's any indication a leak has occurred, or maybe even if not, it's worth pulling off the passenger footwell trim so that you can pull up the carpet and see the wiring along the door jam and above and see if you can identify something obvious like corrosion that would cause something like this. Someone with more experience may come along and provide more/better information.
mshka
Jan 5, 2022 06:02 PM
robdis96
Jan 4, 2013 12:49 PM
outback96
Dec 13, 2009 05:38 PM
marcwestbmw
Oct 2, 2008 09:43 PM
Brad S1
Feb 7, 2007 03:27 PM
