Strange Cylinder Misfire
Old Jan 24, 2022 | 05:49 PM
MadMex's Avatar
8th Gear
i connected an amp clamp to the battery and messured current draw while cranking with a the 2 channel entry level pico scope. saw the dip on the screen.
Old Jan 24, 2022 | 06:36 PM
tracyc's Avatar
So was the scope was on the battery or on the ignition circuit for each cylinder?
Old Jan 25, 2022 | 11:11 AM
tracyc's Avatar
Oh, were you were doing a relative compression test? Is that what you mean by seeing amps dropping on cylinder 3 when cranking?
https://autoditex.com/page/relative-...test-67-1.html
I see why you might think it was mechanical then.
Old Jan 25, 2022 | 01:36 PM
MadMex's Avatar
8th Gear
Yes, relative compression test, I put the clamp on the battery,
Old Jan 25, 2022 | 01:39 PM
MadMex's Avatar
8th Gear
I did the check over a year ago, I've been driving the truck since then with an occasional "reduced engine performance' (I've learned to bypass that by putting the engine in "Neutral Drive" at red lights or stop and go traffic), looking to get around to finally fix it some time soon...Thank you all.
mdwman
Aug 2, 2014 05:24 PM
Fireman
Nov 23, 2010 01:53 PM
casanova00
Jul 28, 2008 10:57 PM
louianquin
Freelander
Jun 9, 2008 03:18 AM
Jawbox
Oct 10, 2007 09:14 AM
