Freelander Talk about the Land Rover Freelander within.
Sunroof leaking - drain tubes
Old Dec 21, 2012 | 09:07 PM
mlelah's Avatar
8th Gear
Default Sunroof leaking - drain tubes
My sunroof is leaking and I suspect the drain tubes are blocked. Can someone tell me where they exit on the sunroof, and where they exit below - the wheel wells/ which ones? I presume there is a valve near the exit that is clogged. Also, what's the best way to clean them out? Blow with compressed air or try to pass a wire through? Thanks.
Old Dec 22, 2012 | 12:23 AM
You will have four drains, one from each corner. Attached are pages from the RAVE service manual. there are over 10 pages of diagrams on sunroofs in the workshop manual. You can download an entire copy for free at links below.
Rover sun roof drains usually break apart inside the head liner.
File Type: pdf
File Type: pdf
Old Dec 23, 2012 | 12:17 PM
mlelah's Avatar
8th Gear
Thanks but the diagrams don't show where the tubes exit at the bottom. Since it is a small leak at the corner of the sunroof I suspect the exits are blocked with dirt,. But I looked all over for them and can't find them. Does someone know exactly where they are? Thanks.
DiscoNoisebox
Jul 15, 2022 10:15 PM
killerpav
Nov 18, 2013 07:37 PM
aftermath431
Oct 4, 2013 10:43 AM
aftermath431
Sep 30, 2013 09:28 PM
bullhead
Jan 19, 2013 02:49 PM
