Suspension
Old Jan 6, 2019 | 04:34 PM
Coop05's Avatar
Default Suspension
Lr3 completely dropped and will not raise.
light with arrows on dash is on and says suspension fault.
need help
Old Jan 6, 2019 | 04:43 PM
DakotaTravler's Avatar
Need codes and a lot more info. Do you hear the compressor startup? How soon after starting does the system disable?
Old Jan 6, 2019 | 04:48 PM
Coop05's Avatar
No codes yet,and right away
Old Jan 6, 2019 | 04:54 PM
Then you likely have a compressor issue. This could be the compressor itself, the control unit, a relay or simply the fuse. I assume you check the fuse?
Old Jan 7, 2019 | 08:55 AM
abran's Avatar
you have to have codes, buy a GAP tool or have them read.
Old Jan 8, 2019 | 12:35 PM
Coop05's Avatar
The codes that came up are PO130 ,PO031,PO130,PO134.
I know i need 02 sensor but will that cause suspension to fault?
Old Jan 8, 2019 | 12:47 PM
Coop05's Avatar
Old Jan 8, 2019 | 03:10 PM
abran's Avatar
the codes need to be read from a tool that reads EAS codes, those are not related to you issue.
RaiderRow
Dec 20, 2021 09:30 PM
Nicepackage
Mar 5, 2019 05:00 PM
blaster1232
Jul 13, 2015 04:37 PM
alti
Oct 25, 2013 10:45 AM
