Suspension Fault , Compressor not running (sorry for another EAS thread)
Old Aug 18, 2019 | 11:21 AM
madtowndisco's Avatar
7th Gear
Default Suspension Fault , Compressor not running (sorry for another EAS thread)
Hello everyone
I’ve read a lot of posts that had to do with suspension faults, and they were helpful. However a couple of quirky things happened with my rover with timing of this failure that I wanted to start a thread to pick your brains. All help is much appreciated
I have 2005 LR3 with 197k miles. It’s been well maintained by its first and last owner before I bought it around 187k as a winter vehicle for me. I absolutely love this beast!
As soon as bought it a year ago I realized it was leaking air because whenever it was parked for 3-5 days it would be way low. It comes right back up when I start so I didn’t bother to fix it, mostly due to the mileage and that would go coils when the compressor gave up. But i didn’t feel like the compressor ran for more than 60sec at morning starts.
Yesterday I had it parked a bit wired with the passenger rear wheel up on a curb for about 45mins. When I drove off, I got the orange warning light and message “suspension fault normal height only”. Now it’s changed to suspension fault special programs not available. And the car won’t raise itself. When I stop ignition and restart no errors, but within a minute it comes back on and I don’t hear the compressor running.
Question 1: is it coincidence or did some sensor go whack when I had it parked crooked? I don’t think so since the error isn’t there when I start but comes on when it realizes the compressor isn’t there to raise the car. Any quick checks I should do to trouble shoot? I already switched the relay with matching relay from windshield heater and no dice.
Question 2: considering it’s age and that it has a leak, is it financial more viable to convert to coil using the kit from Atlantic British? Is there another kit option?
Question 4: I know the car will slowly come down to the bump stops soon, does it hurt the vehicle to be that way for a week or two until I get this conversion done? Does make it difficult to do the conversion if it’s come down in height (probably a dumb question as I think it doesn’t, but I wanted to check)
Again, thank you very much in advance for your help!
Old Aug 21, 2019 | 04:33 PM
7th Gear
Anyone?
Old Aug 21, 2019 | 05:16 PM
houm_wa's Avatar
I'd buy an IIDTool and figure out the issue. Sounds like a compressor, but you can learn more with the GAP tool and it's a good investment anyway. Also, I'd keep the EAS. Change the compressor and the valve blocks and enjoy the ride....have you changed the front shocks yet?
Old Aug 26, 2019 | 04:17 AM
Globetrotter448's Avatar
You can check that the compressor runs okay by pulling the relay in the battery box and bridging the two large slots with a paper clip or solid wire - compressor should run with ign on. If not check the 60/70 amp fuse near the relay and see if its burnt. Current fuse should be 70 amp
Old Aug 28, 2019 | 08:54 PM
7th Gear
Thanks for the tips. Unfortunately they didn’t work so I ordered the coil conversion kit from AB today. With my work travel schedule the LR3 has been sitting on bump stops for over a week now. May sit another week before I can get to it. Does it damage other suspension components if it sits for too long?
Old Feb 15, 2021 | 03:40 PM
bmdubbs's Avatar
I know this is a bit old, but do you have an update as to what the problem & corrective action was?
Old Aug 4, 2024 | 12:05 PM
biomedguy's Avatar
Thanks, but buying a $500 scanner not an option because of cost, and the ISoft does fine, I believe. again, I know its not the compressor, since i can verify operation both on and off vehicle. but thanks.
RaiderRow
Dec 20, 2021 09:30 PM
Nicepackage
Mar 5, 2019 05:00 PM
alti
Oct 25, 2013 10:45 AM
mirepoixmatt
Apr 27, 2012 12:53 PM
