Suspension height calibration
Old Feb 13, 2019 | 01:46 PM
2006 LR3 HD package's Avatar
Default Suspension height calibration
My 06 LR3 has a leak in driver's side front strut. I'm about to replace with new one.
Will I need to have the suspension calibrated? Atlantic British instructional video says its required, but I don't want to take it to the stealership.
Old Feb 13, 2019 | 02:02 PM
abran's Avatar
Not unless you have another issue. But I strongly urge you to change both fronts at the same time.
Old Feb 13, 2019 | 02:56 PM
Thanks Abran.
I wasn't sure about the need to do both sides, know it's recommended with traditional shocks.
Does that create issues if only one side is changed on these air strut suspension vehicles?
Old Feb 13, 2019 | 03:34 PM
abran's Avatar
1- if one went out the other is close behind.
2- The shock portion will be unbalanced as one side is new, other old.
But, won't cause any serious problems.
Old Feb 13, 2019 | 03:49 PM
Thanks Abran.
I also need to replace the rear driveshaft. Atlantic British is out of stock for the gkn driveshaft. Lucky 8 has stock, and its cheaper..only $340. I haven't been able to figure out who makes the lucky 8 driveshaft.
Have guys had good luck with the lucky 8 driveshaft?
Old Feb 14, 2019 | 04:21 PM
abran's Avatar
Lucky8 can get you a GKN as well. Call them.
Porksquid
Feb 16, 2017 03:31 PM
rovernoob
Jun 2, 2015 10:14 PM
spanishfly
Mar 15, 2015 11:33 AM
LRlax11
Dec 8, 2014 04:09 PM
kitoko
Dec 19, 2008 08:15 AM
