Suspension knocking
Old May 4, 2015 | 12:15 PM
fso's Avatar
fso
Default Suspension knocking
Just had the lower control arms, tie rods and sway bar bushings replaced but I'm experiencing some knocking when I go over small to large bumps. Not really a violent knock but just enough to feel dangerous at speed. When on a dirt road there's definitely more knocking. Did the usual checks on bushings, steering shaft etc etc and everything feels tight. There is a little knock when i have someone turn the wheel while feeling the drive shaft but can't locate the source.
Wondering if I can simply tighten up the steering box but cant locate it!
Is this it here? https://www.dropbox.com/s/t7ze4ddaou...14.21.png?dl=0
Thanks in advance!
Old May 4, 2015 | 01:48 PM
houm_wa's Avatar
Someone on this board has a link to tons of videos demonstrating different sounds (tlt I think). That may help you. I was chasing one around about 2 years ago...turned out to be the upper cover on my EAS compressor knocking against my sliders. Lower cover is no longer in use.
Old May 4, 2015 | 02:47 PM
fso's Avatar
fso
THX houm_wa. I'll search for those. Do you have any idea where the steering box is on an LR3?
Old May 4, 2015 | 04:25 PM
houm_wa's Avatar
Sorry, I don't....I haven't really poked my head up there and I don't have a pdf on that.
Old May 4, 2015 | 11:09 PM
Helped chase down a noise on a LR3 that was steering related it was the inner tie rod ends clunking around.
Old May 8, 2015 | 02:29 AM
DavC's Avatar
I have a similar noise when going over bumps (usually while turning). To me it sounds like when you take two rather large rocks and sort of smack them together, or drop one rock on another. Haven't had any problems stem from that per se, but I always imagined it was from the front suspension compressing.
No idea what it is, but I'd be interested to know too.
Old May 8, 2015 | 10:41 AM
houm_wa's Avatar
Check the usual suspects: front lower control arm bushings, sway bar bushings, etc.
Old May 8, 2015 | 11:08 AM
unseenone's Avatar
The inner/outer tie rod ends are sold as a complete kit now. LR010669 left LR010670 right
The usually problem on the steering column is the connection knuckle, not the box. It has a rubber damper built in, and can develop play in it. QMN500250
You should be able to see it, or part of it by looking at the steering shaft from the drivers side, and you will see it bolted on there.
Old May 11, 2015 | 03:04 PM
wbrads's Avatar
Similar issue with a "two rock" hitting each other or knocking when going over bumps. After inspecting all bushings and checking end play on bearings, I can only think its got to be the air shock damper. Driving on the highway, there is a slight shim seemingly like air shock is out.
mowensmd
Aug 21, 2024 11:07 AM
Dtrain36
Mar 5, 2015 07:43 AM
LR03NJ
Nov 18, 2011 09:42 AM
LR03NJ
Mar 5, 2010 07:37 AM
disco1
Mar 3, 2006 10:29 AM
