Tail Lamp Wiring Harness
After replacing the rear, blinker bulb a few times I realized the problem is a loose wire going into the connector from the bulb (yellow, I believe).
Is it possible to repair the wire where it inserts into the connector, do I need to replace the entire harness? Any instructions available?
...out of curiosity, if you don't mind, what project led you to cut off the connectors?
That's very tempting--and generous of you. Still have them? Can I PM you my address? Worse case scenario it doesn't work and I have to buy a new one. Might go with Posi Lock, given I don't have a shrink-wrap gun.
hankeester
09-08-2012 01:13 AM
DiscoRover007
08-26-2012 10:48 AM
twilightcall
03-06-2012 03:11 PM
