Tail Lamp Wiring Harness
Old Aug 7, 2016 | 02:14 AM
scader's Avatar
Default Tail Lamp Wiring Harness
After replacing the rear, blinker bulb a few times I realized the problem is a loose wire going into the connector from the bulb (yellow, I believe).
Is it possible to repair the wire where it inserts into the connector, do I need to replace the entire harness? Any instructions available?
Old Aug 8, 2016 | 10:05 AM
roverguy7's Avatar
Depending on where/how it is damaged, it may be repairable.
If you need to replace the harness, it is available separate from the housing.
P/N YND500080 for US spec vehicles.
Old Aug 8, 2016 | 11:05 PM
abran's Avatar
I just cut some connectors off of the harness of an LR3, if you want to solder the wires and shrink wrap them.
Old Aug 9, 2016 | 09:20 PM
scader's Avatar
That's very tempting--and generous of you. Still have them? Can I PM you my address? Worse case scenario it doesn't work and I have to buy a new one. Might go with Posi Lock, given I don't have a shrink-wrap gun.
...out of curiosity, if you don't mind, what project led you to cut off the connectors?
Old Aug 10, 2016 | 12:23 AM
abran's Avatar
I have ruined a few connectors doing repairs and I wasn't going to pull the whole harness, so I cut off some of the connectors. Also, not that generous of me, I would sell them to you!
Old Aug 10, 2016 | 09:56 AM
scader's Avatar
Ha, fair enough. I can get the whole harness for $40. Let me assess if I think that would be better than splicing in just the connector.
Old Aug 10, 2016 | 11:39 AM
abran's Avatar
I didn't follow the harness back too far, but assumed it was too complicated to pull the whole thing.
Old Aug 10, 2016 | 12:31 PM
scader's Avatar
Ah, well, this is the connector to the bulb side, not to the fuse box side.
Old Aug 10, 2016 | 06:38 PM
abran's Avatar
Yes, I have the bulb side connector.
jfall
Oct 5, 2013 11:19 AM
Peter Van Slyke
Sep 3, 2013 07:39 AM
hankeester
Sep 8, 2012 01:13 AM
DiscoRover007
Aug 26, 2012 10:48 AM
