Tank Pressure Constantly up and down - no leaks
Old Apr 25, 2018 | 09:00 PM
RickyN29's Avatar
Default Tank Pressure Constantly up and down - no leaks
Help!
My LR3 holds perfect height for days on end. New bags, New front and rear valves. Rebuilt hitachi compressor.
However, I noticed when driving the compressor keeps coming on and on. I checked on Gap tool and see that tank pressure is dropped down to 25psi in a couple minutes, compressor kicks on to bring it back up, repeat repeat.
Always needs to run compressor to change to offroad height and takes quite a while. Unless I catch it right when it refills then I get a quick lift.
I’m not hearing any leaks. What in the world could this be?!
Thanks for any advice!
Old Apr 26, 2018 | 12:47 AM
abran's Avatar
Sounds like the tank. Spray it down with windex and look for leaks
Old Apr 26, 2018 | 06:52 PM
RickyN29's Avatar
Even more strange, today I noticed it was holding fine. Does it have an exhaust valve or anything that could be getting stuck open?
Old Apr 26, 2018 | 09:09 PM
abran's Avatar
Compressor has the exhaust valve
Old Apr 26, 2018 | 09:18 PM
RickyN29's Avatar
Thanks! I’ll dig into it and see what I can find. Do you know what normal pressure should be in the gallery?
Old Apr 26, 2018 | 11:14 PM
abran's Avatar
Not off the top but f my head. I will check when I get a chance.
Old May 24, 2018 | 07:52 PM
RickyN29's Avatar
Thought I would update, found a crack in the drier cap! Replaced cap and much better!
Old May 24, 2018 | 08:04 PM
DakotaTravler's Avatar
The metal caps are the best idea if rebuilding/replacing that cap. I have a good spare plastic cap from rebuilding mine if someone needs it. Kit came with a metal one.
Old May 24, 2018 | 08:38 PM
houm_wa's Avatar
Is the cap on the AMK metal or plastic?
Old May 25, 2018 | 09:27 AM
abran's Avatar
AMK doesn’t have the fault prone cap.
Spencerfitch
Sep 27, 2020 12:17 PM
pprussell
May 7, 2013 02:45 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
discoboy
Dec 20, 2012 02:24 AM
Garrison
Jun 4, 2007 11:20 PM
