These cupholder inserts supposed to be removable?
Old Sep 7, 2023 | 11:28 PM
KH406's Avatar
Default These cupholder inserts supposed to be removable?
Dumb simple question - are the cupholder insert supposed to come out easily in order to accommodate larger mugs or a coffee cup?
There are metal accent pieces that were added to my car by the previous owner but if the inserts are supposed to pop out, well in my case they are blocked by the accent piece at the moment
So if this is a feature, then I might carefully remove the metal rings because my cups don't always fit.
But if this was not a feature, then I will not risk accidentally messing up the metal rings that I rather quite like.
(please ignore all the dirt and dog hair lol I just took it car camping all weekend)
Old Sep 8, 2023 | 02:15 AM
loanrangie's Avatar
Yes they should just lift out but like you say looks like the chrome trim has locked them in.
Old Sep 8, 2023 | 11:06 AM
KH406's Avatar
copy that, thank you kindly!
Old Sep 12, 2023 | 03:39 PM
ggDiggs's Avatar
7th Gear
Default Just in case…
I found an easy way to lift them out for cleaning. When my cup is in the holder I do a gentle twist left or right and the insert will lift up attached to my cup. Otherwise I can’t seem to get those suckers to lift out. If the chrome isn’t hindering removal this would be a great way to find out as you don’t have to pull it up - just twist it.
p400_au
Sep 5, 2023 08:51 AM
FirstRoverDisco
Dec 8, 2018 07:47 AM
Lisa Bunch
Jan 24, 2018 04:47 AM
Mskembo
Aug 2, 2016 11:07 AM
BearBait
Apr 1, 2011 11:46 AM
